davestarck
posted on 8/1/10 at 09:38 AM |
MK Indy full cage
I am thinking about fitting a full cage to my Indy R1. Question is can it be done fairly easily on a completed car or is it going to involve welding
etc?
posted on 8/1/10 at 09:47 AM |
I believe you can opt to bolt it in, but even then you would need the relevant plates welded onto the chassis to bolt the cage to.
I considered fitting rear stays and a cross brace to the single roll hoop on my Indy, but couldn't face the aggro of stripping the rear end off
the car to do it.
Kriss
posted on 8/1/10 at 10:29 AM |
I would liek to know too, and also if there is an alternative to the A bars coming into the cabin as they will block my knees between the wheel.
Im very tall!
Bluemoon
posted on 8/1/10 at 12:27 PM |
Im very tall!
Take a look at Caged web site: caged
I like the road sport cage (but will not offer as much protection?), you could think about a similar design..
Caged seem to offer bolt in cages that bolt to the chassis rails using spacer tubes that don't need welding worth a look to see how they do
this..
Dan
Nash
posted on 8/1/10 at 01:04 PM |
Not sure about he integity of that in a smash? Cage is only as strong as its weakest link..... Anne
.........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
Bluemoon
posted on 8/1/10 at 01:44 PM |
^^ true, but you are still going to attach it to a peace of 25mm box, the bolts (so long as they are sized correctly) will not go first cross sections
is probably larger than the boxes.
Getting the design good enough is key, and this is something caged know about and I don't.. i.e. you need to spread the loads into the space
frame "correctly".
The cage design is using the chassis as part of cage if you like (the bottom half). No idea if the caged design is good or not but they are supposed
to be experts at it, and have a lot more experience of roll cages than MK.
Dan
[Edited on 8/1/10 by Bluemoon]
Nash
posted on 8/1/10 at 02:30 PM |
^^^ accepted. But if the car rolls the downward force on the top chassis rails will be lateral not in compression whereas if your cage goes to the
floor the force pushes down the leg of the cage in compression and that means less deformity of the whole structure.
An example if the Chassis rail deforms 4" in a rollover chash that means the top of the rollcage will deform 4" I don't think the
top of my head is much more then 4" from the underside of the cage top bar.?!
........Neil
[Edited on 8/1/10 by Nash]
Bluemoon
posted on 8/1/10 at 02:54 PM |
^^ Good point I guess this is why the other caged cages pick up further forwards of the windscreen (i.e. where there is a cross member running from
each side of the car. Snag is you can't do this if you want weather gear..
I think caged have got around this to some extent by having a diagonal tube across the top of the cage, thus any longitudinal forces are transferred
to the back hoop...
Also the bolt position is directly above a vertical tube down to the bottom of the chassis. So with the cross bar I guess this is pretty much the best
that can be done.
Anyhow this is getting off topic, and I am not an expert!
Dan
iank
posted on 8/1/10 at 03:02 PM |
If you want to go racing then be aware of the MSA regulations.
This thread contains some good information:
http://www.locostbuilders.co.uk/viewthread.php?tid=127272
Anonymous
Bluemoon
posted on 8/1/10 at 03:15 PM |
^^ Having just read that link I don't think caged will not be on my list of cage suppliers, procomp mention of not being able to get the corner
weights correct after installing the cage because of the chassis flexing says it all. Still better than a single hoop I suppose. Proper advice is
required I think from a real expert (not may of them about I feel).
Dan
davestarck
posted on 9/1/10 at 09:51 AM |
Emailed 'caged' and got this reply.
We fitted a cage to a MK indy before Christmas in the same style as our Westfield cage see the web site for photo’s, we would need to drill 8 holes in
the body for the bolts, there should be no need for welding.
Price for this would be £750 +VAT fitted we would require the car for about a week
Kind regards
Rob
woodster
posted on 9/1/10 at 09:59 AM |
just my 10ps worth i always think a full cage on an indy makes for a better looking car
welderman
posted on 9/1/10 at 10:19 AM |
out of interest, what size material do caged use, it looks smaller than the 48 i use, ive done a few weld in cages, but have been asked to think about
doing a bolt on one with side bars.
Joe
Thank's, Joe
I don't stalk people
