eznfrank
| posted on 23/2/10 at 02:27 PM |
Top hat for cable to p[ass through bulkhead?
Has anyone found a decent solution for how to secure the cable as it comes through the bulkhead at the pedal end (on an Indy if that makes a
difference). I don;t mean the nipple, I mean the bit that stops the sheath moving?
cd.thomson
| posted on 23/2/10 at 02:31 PM |
If I've read that right then I'm also interested in the answer as I'm sure my outer cable needs some kind of double rimmed top hat
fitting to it.
Craig
stevec
| posted on 23/2/10 at 02:35 PM |
I turned a top hat from a bit of nylon bar and drilled it through then drilled half way slightly larger to hold the cable.
Steve.
blakep82
| posted on 23/2/10 at 03:00 PM |
the cable usually (not all of them do though) has a stepped metal end on it that goes into an adjuster. all you need is a plate with the right size
hole in it
if your cab;e hasn't got a stepped metal end on it, i'd look for another one that does
________________________
Coopz
| posted on 23/2/10 at 03:17 PM |
Mac1 supply what your after.
martin1973
| posted on 23/2/10 at 07:33 PM |
i used a rivnut
n tapped a thread on the cable end so it screwed in the rivnut
did the same the other end too
only because i remembered how they used to work on chopper bikes
martin
| posted on 23/2/10 at 07:52 PM |
On our Davrians we use the bottom bit of a rubber snap in tubless tyre valve.
Mark G
| posted on 23/2/10 at 08:32 PM |
I got mine direct from MK.
