New Topic New Reply
Author: Subject: Zetec oil filter and steering link
L5W
posted on 24/2/10 at 07:15 PM Reply With Quote
I've got an issue with the oil filter on an early 2.0L zetec from a mondeo and the steering column link.
I've been doing some searching on here and can see that Coozer got round this with a remote filter but looking at the clearance on mine, I don't think there is enough room.
Other searches mention adding a new support, a rose joint and a second u/j link. If anyone has some pictures of how they've done theirs that would be great!
Thanks,
Lee
mad4x4
posted on 24/2/10 at 07:34 PM Reply With Quote
I had the same problem
I moved my steering rack over so that steering connect other side of the chassis leg
Scot's do it better in Kilts.
big_wasa
posted on 24/2/10 at 07:36 PM Reply With Quote
There are two differant oil pumps. The second may give clearance for a remote filter.
L5W
posted on 24/2/10 at 08:03 PM Reply With Quote
Thanks for the replies, i didn't know there were two types of oil pumps for the zetec, will look into it
robocog
Faced the same issues in mine
Went with a shorter pump (1.8 Fiesta /Escort item) and remote filter plumbed in
Regards
Rob
theconrodkid
posted on 24/2/10 at 08:29 PM Reply With Quote
i put an extra UJ in the shaft and used a renault 5 turdo oil filter,they are thinner than a thin thing on a diet
who cares who wins
pass the pork pies
lotusmadandy
posted on 24/2/10 at 08:32 PM Reply With Quote
Yup, i had the same issue on my indy.
I modified my shaft with a support bearing and an extra u/j.
I have enough room to fit a full size mondeo filter in now.
austin man
posted on 24/2/10 at 09:35 PM Reply With Quote
done 2 zetecs now on with the third I weldet another tubue between the botom chasis rail and the round diagonal, mountes a bracket onto it. Cut the steering shaft and welded in another uJ some pics in my archive of the first install we used a suspension bush to carry the shaft, 4 year on and no significant wear
the car was an MK
austin man
posted on 24/2/10 at 09:41 PM Reply With Quote
MK steering mod latest 2010
Most recent modification
L5W
posted on 24/2/10 at 10:35 PM Reply With Quote
Thanks again for the replies and the photo, its given me plenty to think about
James
posted on 24/2/10 at 11:42 PM Reply With Quote
Take care if you go this way- Renault 5 is not the correct thread. It fits, but it's not on right and couple of people have had major leaks.
Hopefully someone who knows more will post as I can't remember the correct filter.
James
zetec
posted on 24/2/10 at 11:47 PM Reply With Quote
Tilt the engine slightly down and to the left and the filter will fit just under, that said I did make my own mounts. No problems after 8000 miles. Rescued attachment DSCF0029.JPG
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
bob
posted on 26/2/10 at 12:00 AM Reply With Quote
Yup as zetec pushed the engine over a few mm's and a very slight tilt was enough to fit the smaller oil filter.
The renault 5 turbo filter is not the exact thread size BUT and its a big BUT, you do not have to tighten oil filters by hand until your fingers bleed.
Have used the renault filters for the last 3 years with no problems at all. Rescued attachment parts0742.JPG
L5W
posted on 26/4/10 at 07:14 PM Reply With Quote
I mocked up the mod I'm planning to do to the steering link to clear the oil filter. A few photos below.
Can anyone can spot anything that might cause a problem before i got ahead and tidy the box section post and then weld it onto the chassis plate?
Thanks,
Lee
whitestu
posted on 28/4/10 at 07:42 AM Reply With Quote
+1
stu
posted on 28/4/10 at 08:01 AM Reply With Quote
Hi, not wanting to compromise on oil filter capacity (trying to keep it OEM and because of the thinner oil zetecs use) I manipulated the engine around a bit when I was making mounts to give me enough clearance for a remote and full size filter.
Lotusmadandys and Austin Mans solution was very neat and can easily be achieved.
New Topic New Reply
