RIL2002
| posted on 26/2/10 at 05:48 PM |
Ford Sierra 1.8 Turbo Diesel
Anybody know apart from the engine if a ford sierra 1.8td running gear etc and rest of car is the same as the 1.8/2.0 pinto cars?
stevec
| posted on 26/2/10 at 05:54 PM |
Little things like no efi pump and revcounter may be different if you are using the clocks.
mcerd1
| posted on 26/2/10 at 05:58 PM |
it'll have a type 9 gearbox with a long input shaft (like the V6 ones) and a slightly longer bellhousing to match
[Edited on 26/2/10 by mcerd1]
RIL2002
| posted on 26/2/10 at 06:12 PM |
mcerd1+ steve,
Cheers for that lads, not caring about engine and box, just running gear, diff ,steering colum etc for donnar pack
Rik
mcerd1
| posted on 26/2/10 at 06:20 PM |
I'm sure some one will give you a couple of beer tokens for the box then
AndyGT
| posted on 26/2/10 at 06:34 PM |
Diff ratio may suit the BECers asit is a higher ratio. Can't remember the ratio now
nothing is impossible
everything is possible
Mark Allanson
| posted on 26/2/10 at 06:39 PM |
The 2.3 Peugeot engined sierra had the 3.15:1, the 1.8 TD usually had the standard 3.92:1
RIL2002
| posted on 26/2/10 at 06:57 PM |
The diff would suit me fine as I have a bec indy at the min and its 3.9 and was thinking about going that route again
Mark Allanson
| posted on 26/2/10 at 07:09 PM |
Rear drums will give better brake balance as well - and an easy handbrake pass.
| posted on 26/2/10 at 07:44 PM |
Lot to be said for rear drums
mcerd1
| posted on 26/2/10 at 08:01 PM |
most of the 1.8D's I've seen have had 3.62 diffs - but the vin plate will soon tell you
http://www.locostbuilders.co.uk/viewthread.php?tid=85080
