mad4x4
posted on 4/5/04 at 10:29 PM |
Clutch Pedal
On so how are you setting this up. I have made my own pedal but have no idea how to connect the cable and set up an adjuster.
What sort of distance will I need between the furlcrum (Piviot point) and the cable attachment.
Engine/Gearbox is a ford 1.8CVH gearbox and XR2 engine.
Chassis is MK Indy (2002/2003)
Scot's do it better in Kilts.
posted on 4/5/04 at 11:12 PM |
Maybe...
you will find something on our site - but our's is for a BEC - connection cant be that much different can it?
Around November or December - could be some in our photo archive too!
Jonte
posted on 5/5/04 at 05:08 PM |
Just another thought.
With pinto-engine and MT9 gearbox, is there any spring on the clutch-cable?
Click it
mad4x4
posted on 6/5/04 at 09:05 AM |
No spring on the Cable as far as I can tell.
Can manage the gearbox end easy. What about the pedal end.
posted on 6/5/04 at 10:04 AM |
The clutch diaphragm supplies the spring but a return spring at the pedal will help release the last bit so the bearing doesn't rub. My locost
has a Mk2 Escort pedal and Capri cable (same). I just cut the pedal and put a straight piece in it.
[Edited on 6/5/04 by Peteff]
