Breaker
| posted on 17/4/10 at 06:14 PM |
Question to MK Indy R owners
Hello,
End of last year I picked up my MK Indy R deluxe kit. This weekend I was trial fitting the front suspension and I seem to be missing some parts ?
I have the front rods to connect the suspension to the inboard shocks, but I can't find the rod end bearings + bushings for this ?
I thought these were included in the kit ?
I also seem to be missing some kind of bushings for the pedals....
austin man
| posted on 17/4/10 at 07:04 PM |
I believe it is a bolt that is used and shimmed with washers either side. The pedal bushes are a black hard plastic / nylonand accept a M6 bolt
jack_t
| posted on 17/4/10 at 07:13 PM |
correct there is no spacers for the rod ends you have to use washers or make a spacer
and the pedals should have a nlyon insert ( its what i would call a reducer and it is m8
Breaker
| posted on 17/4/10 at 07:15 PM |
OK, but the rod ends and the nylon inserts should be included in the kit, right ?
austin man
| posted on 17/4/10 at 08:05 PM |
not sure the rod ends you refer to are rose joints, if the Indy r is a comprehensive kit then I would have thought they would be included
jack_t
| posted on 17/4/10 at 08:09 PM |
the actual rod end/ rose joint is included in the kit as are the nylon bearings but the spacers that stop the rod ends/ rose joints from sliding
laterally on the bolt are not
Breaker
| posted on 17/4/10 at 09:54 PM |
Ok, I'll take another look. Otherwise I think MK has forgotten to add it to the delivery. I'll contact them...
Dan
| posted on 18/4/10 at 09:49 PM |
The spacers came with my kit give them a bell their a decent bunch.
