oskins
posted on 16/5/04 at 09:00 AM |
length of driveshafts
We are making a locost with a slightly changed chassis. We bought from Martin Keenan his rear top and bottom wishbones and uprights. We measured the
pitch between the top wishbone brackets (584 mm, 23”) and bottom wishbone brackets (508 mm (20”) from an indy chassis. We are now trying to put
everything together. It seems that either the driveshafts are too long and therefore need shortening or that the measured pitch between the brackets
is too short. Can someone please confirm the fact that either the driveshafts need to be shortened or that the measured pitch is too short, because it
seems that the driveshafts need to be pushed in too far. Our distance between the outside faces of the uprights (when both are precisely vertical) is
1364 mm (53 11/16”). We think they should be a few mm further apart. Can someone please confirm this. we use the standard Sierra diff and
driveshafts.
matt_claydon
posted on 16/5/04 at 11:55 AM |
My Indy was just like this. There is loads of 'spring' in the CV joints so when you tighten the bolts up, the shaft just gets a bit
shorter. This allows it to elongate when the suspension moves up or down.
Matt.
P.S. Don't forget one shaft is longer than the other!!
zetec
posted on 16/5/04 at 12:23 PM |
As said driveshafts are not shortened. I'm sure you know, but one is longer than the other.
shortie
posted on 16/5/04 at 07:02 PM |
just out of interest I am sure it will be obvious when I go to fit them but which side does the shorter shaft go??
Rich.
phelpsa
posted on 16/5/04 at 08:05 PM |
On the left.
Adam
shortie
posted on 16/5/04 at 08:18 PM |
left as you look at the front of the car??
Jasalarms
posted on 17/5/04 at 05:51 AM |
Shortie, if you look at my pic, the diff is offset to the passengers side, so the short shaft will go on the left looking at the rear and the longer
one on the right
[img][/img]
shortie
posted on 17/5/04 at 02:18 PM |
looks pretty obvious, just never looked that closely at the diff.
thanks,
Rich.
oskins
posted on 17/5/04 at 06:10 PM |
Thanks Matt_Claydon.
When you say that the shafts just get a little smaller by pushing the springs inside the shafts in, do you do that for roughly a little over an inch?
Because that was the fact in our situation. Therefore we would like to have some information about the dimensions we mentioned in our first message.
We worry about the measured dimensions, since it is now clear that the driveshafts don't get shortened.
P.S. Indeed, we did not miss the fact the left driveshaft is shorter than the right one.
matt_claydon
posted on 18/5/04 at 08:05 AM |
If I remember correctly it was about an inch - I thought it was a lot at the time but have had no problems. You would probably find it was the same on
the sierra donor if you could go back in time and check!!
James
posted on 18/5/04 at 03:09 PM |
Oskins,
I've done my own IRS so it scared the sh1t out of me when I thought they were too long!
Just push them in and forget about it!
HTH,
James
