Cubby
posted on 28/5/10 at 11:07 AM |
MT75 Bearing Overhaul
Anyone done an overhaul on an MT75 g/box ?
I've got a spare box which has a noisey main shaft bearing . Fancied a go at it myself .After all how difficult can it be !!!!
Have a feeling it might require specialist tools so might not be a goer ?
big_wasa
posted on 28/5/10 at 11:47 AM |
I am sure there is a service manula floating around the net some where. I will have a butchers when I get home.
I will say that a bearing will cost you more than a good used box. there not the most poular and often sell for £30. unlike the T9 which often fetches
over a ton on ebay these days.
Cubby
posted on 28/5/10 at 12:05 PM |
Thanks much appreciated. As I say just fancied a crack at it. local firms want close on £400 to overhaul it and as you say you can pick them up quite
cheaply but at least I know the one I have which used to on the car has no other issues .
It probably is quite straightforward apart from any specialist tools which always tend to make it not a viable proposition for the home mechanic !!
