Davegtst
| posted on 15/6/10 at 09:57 PM |
Which master cylinder
I've been searching for a while and can't really decide which brake master cylinder i need. I've read up about using early fiesta
ones, sierra ones mounted at an angle and found there are different sierra ones but what one do i need and where is the best place to get one? I
didn't get one with the other donor parts so have nothing to compare.
Andybarbet
| posted on 15/6/10 at 10:16 PM |
My kit came with a bias bar pedal box, if you decide to go that way instead, your welcome to try it for size.
t16turbotone
| posted on 15/6/10 at 10:23 PM |
Fiat 124 M/C (bmc4020) mounts on correctly on vertical plate remote res, correct bore all for £17! brakes international
austin man
| posted on 15/6/10 at 10:31 PM |
usual MK one is a sierra one there are a couple of variations, I had a replacement on which required me to widen the hole on the bulkhead
Davegtst
| posted on 15/6/10 at 10:53 PM |
Sounds interesting. Do these work well with standard sierra calipers?
whitestu
| posted on 16/6/10 at 08:40 AM |
I have this mc as well and it works really well with standard Sierra brakes.
Stu
Davegtst
| posted on 16/6/10 at 08:51 AM |
Is this the one? How is it plumbed in?
mc
[Edited on 16/6/10 by Davegtst]
whitestu
| posted on 16/6/10 at 11:03 AM |
If you look under 'Fiat 124 excl sport', it is part number BMC4020 - £16.20 ex vat.
The brake pipes connect in the same way as any other tandem MC - split circuit to front brakes, singe circuit to rear.
You then need suitable hose to connect the two fluid inlets to a reservoir. For IVA you will need a reservoir with a level switch.
Stu
Davegtst
| posted on 16/6/10 at 09:21 PM |
Thanks for all your help. Looks like i'll be ordering one of those.
omega 24 v6
| posted on 17/6/10 at 10:06 PM |
What are the sizes of the reservoir hoses?? this may be the ideal solution
( and cost ) for me as well. So where to get hose and a reservoir??
Oh and will I still need my escort pressure valve in the rear line to keep the front to rear ratios still be the same.
[Edited on 17/6/10 by omega 24 v6]
Davegtst
| posted on 23/6/10 at 12:22 PM |
Got my 124 master cylinder today. Fantastic service from brakes international, only ordered yesterday. The hose would need to be 8mm which can be
bought from CBS as well as the resovoir.
