bi22le
posted on 23/7/10 at 06:40 PM |
Are the sumps on a 4age Blacktop and a silvertop the same?
As title.
I would like a spare sump for my 20V Blacktop 4age. I want to shorten and wing it as a winter project.
If the silvertop are the same it greatly increases the chances of finding one.
If you have a Blacktop 20V sump for sale. U2U me. I have monies!!
Please read my ring story:
russbost
posted on 23/7/10 at 06:53 PM |
further to the above Q & obviously relevant to availability does the 16v sump fit the 20v or are they completely different (think they are the
same block, but may be showing my ignorance here )
bi22le
posted on 23/7/10 at 07:01 PM |
Cheers for making my Q a bit clearer Russ.
I always thought they were the sme block but different internals and head. Hopefully we are right.
Werner Van Loock
posted on 23/7/10 at 07:53 PM |
16v and 20v are different as I got hold of a raw alloy sump from someone that converted to a 20v
http://www.clubstylus.be
oldtimer
posted on 24/7/10 at 06:55 AM |
^^^^What he said, Raw shortened and winged my 20v blacktop sump.
russbost
posted on 24/7/10 at 10:08 AM |
Anyone know what's different, as if bolt pattern is the same it still might be poss to mod the 16v sump (as it's pressed steel &
therefore readily weldable) rather than mod a 20V (which is alloy?? I think?)
bi22le
posted on 24/7/10 at 12:24 PM |
I think a call to raw is require. I'll also put up a cost inn some other forums I frequent to see if they know
