beer monster
| posted on 27/7/10 at 07:38 PM |
speedo healer
does anyone know the speedo healer settings for an mk indy with a 3.64 diff with a 1998 fireblade rrw lump?mine has lost formulae?
thanks
marc
jase380
| posted on 27/7/10 at 08:02 PM |
you need to put a gps or something to give you an accurate speed in the car then go onto the speedohealer website and use the online calculator to
give you the right value for indicated speed (on your speedo )against actual speed on the gps. unplug the speedohealer first before checking the road
speed.
hobbsy
| posted on 27/7/10 at 11:27 PM |
Need to know your wheel sizes etc.
The way I did mine was reset it so it does not correction then go out with a GPS (and ideally a passenger!) then go to 70mph on the GPS and record the
speed on your speedo (with no correction).
Then divide one by the other and that's the correction factor you need (can't remember off hand if its a multiply or divide factor without
looking at the instructions but you get the idea)
