New Topic New Reply
Author: Subject: QUICK RACK QUESTIONS.?
GeoffB
posted on 1/6/04 at 07:59 PM Reply With Quote
WHAT YOUR VIEW ON DRIVING WITH 4.2 TURNS ON AN INDY.?
IF I USE A QUICK RACK KIT ie (rally design) DO THEY JUST GO STRAIGHT IN TO THE SHORTEND RACK.?
Jasalarms
posted on 2/6/04 at 05:55 AM Reply With Quote
Hi GeoffB,
4.2 turns does seem alot, but once coupled to a 11"steering wheel things should be better.
Martin did advise me that a quick rack on normal roads is a bit lively, as you can end up on the other side of the road if you even sneeze, but on a trackday would be great.
But again some of the BEC Indy boys have had one fitted and have not complained.
The Quick rack will have to be shortened as well.
Good luck with getting one from rally design, as i waited 6 weeks for one!
Gave up in the end, will get one if i find the steering a bit boring when it gets on the road!
posted on 2/6/04 at 07:17 AM Reply With Quote
Try going straight to Quaife if you decide to get one - they supply most of the regular outlets!
marc n
posted on 2/6/04 at 07:22 AM Reply With Quote
Hi guys
we have these in stock already shortened and ready to use, and can also supply you a shortened rack body off the shelf too
regards
marc
www.mnrltd.co.uk
phelpsa
posted on 2/6/04 at 07:39 AM Reply With Quote
SIX WEEKS!! I got mine the same week as I ordered it.
Adam
Jasalarms
posted on 2/6/04 at 02:22 PM Reply With Quote
Yep six, apparently they had a serious shortage back in late march to early april......... got to go ive think i have some glassfibre dust down the back of my shorts
Bloody side panels!
chrisg
posted on 2/6/04 at 06:40 PM Reply With Quote
MK have them in stock - £105 inc vat
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
alister667
posted on 2/6/04 at 09:06 PM Reply With Quote
Chris
Chris,
Are those racks already shortened to fit into the MK Indy modified rack case?
Marc N,
How much are your shortened racks?
Does anyone know are they east enough to fit into a modified steering rack casing?
Thanks guys.
Ali
[Edited on 2/6/04 by alister667]
http://members.lycos.co.uk/alister667/
heyzee
posted on 2/6/04 at 09:17 PM Reply With Quote
quick rack
they are quite easy to fit into the shortened rack.i fit mine in my dinner halfhour at work,but it just needs tensioning up now with the nylon slipper and the track control arms and boots fitting
marc n
posted on 2/6/04 at 09:41 PM Reply With Quote
Hi Alister £98 inc vat
regards
marc
marc n
posted on 2/6/04 at 10:40 PM Reply With Quote
we get them full length then shorten them to what people require, for mk applications on average we need to reduce them by an extra 20mm although they do seem to vary slightly from rack to rack, so best to measure
hope this helps
regards
marc
marc n
posted on 2/6/04 at 11:07 PM Reply With Quote
appologies snoopy just realised your connection and which section this is in, guided to this thread via new thread section on opening page nether thought to look which category it was in !!!!!!!!
regards
marc
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 5/6/04 at 05:46 PM Reply With Quote
Just fitted quickrack supplied by marc n to my Indy......... and its brilliant! has transformed the 'feel' of the car- much more surefooted and direct. Rack was out car, changed, back in car and driving down the road in an hour and a half! top service from marc n- highly recommended! and i prob would have got one from mk snoopy but didn't realise they were back in stock!
New Topic New Reply
