Cubby
posted on 11/8/10 at 08:08 PM |
Engine/Gearbox alignment
One line of investigation regarding my gearbox issues(bearings failling very quickly) is that it might be a misalignment between the engine and
gearbox ie the gearbox input shaft is not aligning precisely enough with the engine crankshaft spigot bearing.
Now the engine / gearbox setup when used in the production (tintop) have dowels on their flange faces to align the gearbox onto the engine. Matching
the Gearbox (MT75) to the Zetec these dowel /dowel holes do not match up so cannot be used to centralize/align the gbox to the engine.
Have others just removed and disgarded these dowels and assume the flange bolts around the gbox are accurate enough for alignment ? Is it an issue
Has anyone dialled in the bell housing (accurately centred it on the engine) and
installed new dowels ? If so any tips will be much appreciated !
big_wasa
posted on 11/8/10 at 08:10 PM |
Just checking, you have stuck a spigot bearing in the end of the crank ?
Cubby
posted on 11/8/10 at 08:14 PM |
Yep !
Dusty
posted on 11/8/10 at 10:51 PM |
Matching the Gearbox (MT75) to the Zetec these dowel /dowel holes do not match up
Are you sure? They do on my zetec to type 9. Hollow dowels in the bolt holes at 3 and 9 o'clock which the bolts go through. I thought it
was the same with the MT75.
alistairolsen
posted on 12/8/10 at 06:47 AM |
the dowels fit fine!
My Build Thread
Cubby
posted on 12/8/10 at 08:59 AM |
Thanks I'll go recheck
Cubby
posted on 12/8/10 at 10:25 AM |
Done a recheck(d0wel locations at 3&9 0'clock) but unless I'm missing something I still don't have the engine dowel location
tying up with the gearbox holes .As you can see from the pictures the engine locations fall in the are outside the gearbox flange with only the
blanking/spacer / sandwich plate to locate instead of locating directly with the gearbox ???
Zetec Blacktop -> Mt75
Sorry but given up trying to upload the pictures.
alistairolsen
posted on 12/8/10 at 11:31 AM |
You havent still got the shitty plate behind the flywheel have you? Bin it, the one on the inlet side should fit fine and the one on the exhaust side
might need looked at.
My Build Thread
Cubby
posted on 12/8/10 at 01:30 PM |
Yes I have . I'll remove it and take a look. Many thanks for your help.
alistairolsen
posted on 12/8/10 at 01:39 PM |
youll find that even if you could get it to bolt up the starter wouldnt fit!
My Build Thread
