Dave Bailey
posted on 26/8/10 at 09:14 PM |
Engine Run On
Well the engine runs however when i turn the ignition switch off the engine runs on for a second or so then dies.. I suppose it could be ignition not
quite right.. I need to check to see...
Anyone had a similar situation?
It is also possible that it is normal...
thanks
Dave B
55ant
posted on 26/8/10 at 09:17 PM |
had this with a pinto that didnt have the spark timing set up properly after a cam change, just set the timing and it was sorted.
away from cars, now cycling and building TT bikes
RichardK
posted on 26/8/10 at 09:31 PM |
could be feed back from either the alternator driving the charge lamp or cooling fan doing the same, this could be resolved by inserting a couple of
diodes into the wires.
Rich
Gallery updated 11/01/2011
hillbillyracer
posted on 26/8/10 at 09:36 PM |
If everything is right & you still get it too much you can get a valve which opens when you cut the ignition letting excess air into the inlet
manifold downsteam of the throttle so it weakens the mixture a lot & stops it. Really it's a cure to a problem that should'nt be there
if all is well but I've seen them factory fitted (but that was British Leyland which mabye says it all!)
nitram38
posted on 26/8/10 at 10:07 PM |
Could be too your idle is too high or sticking?
zetec mike
posted on 26/8/10 at 10:15 PM |
First thing to find out is if the sparks stop when you switch off. If they do check for timing/ mixture/ high idle etc. What engine ?
Dave Bailey
posted on 26/8/10 at 10:55 PM |
Engine is ST170.. on a DTA ecu...
nitram38
posted on 27/8/10 at 05:25 AM |
Automatic Choke stuck on?
posted on 27/8/10 at 07:23 AM |
Idle speed too high & weak mixture at idle, if that doesn't fix it fit an ant-dieseling valve
HOL
posted on 27/8/10 at 10:02 AM |
Back in the days of distributors, this always happened on my RWD Escorts if the ignition was too far advanced at tickover.
Does the car spin over cleanly when you turn it over? Or does it slow down mid revolution?
Might be an idea to tweek the map between 500-1000rpm.
Super Six Sold -
Proton AWD Turbo Hatch Track Car.
Dave Bailey
posted on 27/8/10 at 11:34 AM |
Thanks guys... I'll have a play over the weekend.
