scoobyis2cool
| posted on 7/6/04 at 05:05 PM |
MK pinto pickup pipe problem
I got my engine up and running at the weekend but there was a loud banging noise coming from inside the sump. I took it off to have a look and found
that the crank is hitting the pickup pipe (which I got from MK with my modified sump), and has so far taken a fair chunk out of the pipe in 2
places.
Has anyone else had this problem with their pipe or am I alone?
Pete
Staple balls
| posted on 7/6/04 at 05:50 PM |
eep
can you post a picture?
scoobyis2cool
| posted on 7/6/04 at 05:53 PM |
Yeah I'll post a photo later, I'm at night class at the moment (working really hard!)
Pete
scoobyis2cool
| posted on 7/6/04 at 08:55 PM |
Photo...
Here's the photo of the pipe, you can see the 2 grooves quite clearly
Pete
| posted on 7/6/04 at 11:28 PM |
well, its either the pipe too close to the crank, or the crank too close to the pipe. did you use all three bolts? the two by the oil pump and the
bracket further down? if these are all in place, then maybe the crank is loose! but i dont know sh1t about engines so who knows...
scoobyis2cool
| posted on 8/6/04 at 12:20 AM |
Yeah I used all 3 bolts and I'm pretty sure the crank isn't loose! The engine ran fine in the sierra, I think the problem is the mounting
bracket has been modified and must move the pipe too close to the crank, I may be able to pack it out or failing that I'll just have to hammer
it about a bit to make it fit better!
Pete
[Edited on 8/6/04 by scoobyis2cool]
scoobyis2cool
| posted on 8/6/04 at 01:50 PM |
Sorted it now, as usual brute force prevailed! Now onto that annoying misfire...
Pete
Mark Allanson
| posted on 8/6/04 at 09:01 PM |
No sh1t sherlock ......
[Edited on 8/6/04 by Mark Allanson]
| posted on 8/6/04 at 09:23 PM |
smart git me, you know!
