noc231073
| posted on 4/11/10 at 11:47 AM |
Spilt brake system
Iam thinking of getting rid if the standard sierra master cylinder and fitting a balance bar and and two brake cylinders one for the front and the
other for the rear with remote reservoirs anyone done this ? If so what size master cylinders would you used for both front and rear
RazMan
| posted on 4/11/10 at 12:09 PM |
A lot depends on your caliper piston sizes. What calipers do you have now?
Raz
noc231073
| posted on 4/11/10 at 12:27 PM |
willwood 4 pots on the front and standard sierra on the back
RazMan
| posted on 4/11/10 at 12:51 PM |
I assume you have Dynalites on the front, in which case 0.625" front and 0.7" rear.
Raz
noc231073
| posted on 4/11/10 at 01:33 PM |
There actually powerlite , 1.38, 35/.50. If that makes any sense
RazMan
| posted on 4/11/10 at 01:46 PM |
35mm pistons are the same as the Dynalites so those sizes should be a good starting point for you.
Raz
noc231073
| posted on 4/11/10 at 02:31 PM |
Cheers for that
| posted on 4/11/10 at 07:57 PM |
Just out of curiosity more than anything else - what are you hoping to gain by having a dual braking system?
Phil
noc231073
| posted on 4/11/10 at 08:54 PM |
i plan to hillclimb and sprint my mk ....some motorsport disaplines call for a dual system ....its safer and gives an easy way of adjusting brake bias
noc231073
| posted on 4/11/10 at 08:56 PM |
and it also allow fitting of the right size master cyclinder to suit your caliper front and rear
| posted on 4/11/10 at 09:04 PM |
I was going to suggest fitting a brake bias valve instead but if you require a dual system for some disciplines of motorsport, then you don't
have this option........
Phil
