noc231073
| posted on 5/1/11 at 07:56 PM |
Exhaust silencer mounting
Where and what why do you mount the silencer
Is it to the bottom chassis rail
My exhaust seems way to high to mount to the chassis rail
dhutch
| posted on 5/1/11 at 08:00 PM |
Mines actually attached to the floor with a angled bracket that then goes up the side of the car, although some are mounted through the body work.
jacko
| posted on 5/1/11 at 08:46 PM |
This is mine a z bracket from under the floorand a bolt in the bottom rail
noc231073
| posted on 5/1/11 at 09:38 PM |
That looks tidy cheers for the pic
Bluemoon
| posted on 6/1/11 at 09:22 AM |
Also it's the "correct" way to load the rubber mount, if you simply bolt to the side panel (i.e. a vertical surface) the mount is
under shear and will fail early..
Dan
noc231073
| posted on 6/1/11 at 06:02 PM |
Btw. My mk silencer is extremely heavy as it probably packed to reduce noise
What other silencers could you use to reduce weight if noise wasn't an issue could you use a carbon fibre bike exhaust for instance
