beer monster
posted on 31/1/11 at 09:56 PM |
upgrades
hi all have done a few track days in my mk indy 919 blade and i was looking fine tune things to get a bit more ouy of it.i am currently running a
standard air filter and box.firstly how can i get the best out of it.dynojet kit?sausage filter? or a rolling road session and get suspension properly
set up.i have to say i am not particularly impressed by handling.seems to be a bit vague going into corners.when i built it i set it up to mk's
specs,cant remember what that was now.also anyone recommend anyone in kent area to set up?also what tyre pressures and damper settings are others
using.
many thanks
marc
cliftyhanger
posted on 31/1/11 at 10:04 PM |
Getting what you have set up properly will be the best approach. Assuming the engine can be tuned etc.
The handling may well benefit from proper alignment if you are not absolutely certain it is spot on. alignmycar.com has a decent system, not cheapest
but does the job properly. Make sure any specs you supply are correct, you may need to sit in the car or use weights as that can make a significant
difference.
Major Stare
posted on 31/1/11 at 10:08 PM |
My list would be the following.......
Reduce un-sprung weight (fit 13" wheels)
Remove any excess weight & use carbon where required.
Aluminium Hubs
Aluminium 4pot calipers
Uprate suspension (if needed)
Settup suspension
Keep standard air box
Tuned manifold exhaust and air filter (rolling road again)
Fit Power Commander
Rolling Road
Jon "FISH"
adithorp
posted on 31/1/11 at 10:12 PM |
Get the set up done.
http://jpsc.org.uk/forum/
beer monster
posted on 31/1/11 at 10:15 PM |
can you fit power comander to a carb engine?think thats only for injection?mine is 1998 rrw engine.also when corner weighting what weights would you
use?should front and rear match?presumably as engine in front this would always be heavier?or should you add weight to rear?any recommendations of
companies in kent area that could do this?thanks for responses so far.
marc
snapper
posted on 31/1/11 at 11:11 PM |
Tuned intake lengths and exhaust lengths matched to the cam.
If you are running the bike inlet and carbs then you just need to mirror the bike exhaust manifold, most kit car exhausts are made to fit the body and
are not the right length for a bike engine.
Corner weights, tyre pressures, geometry.
I eat to survive
I drink to forget
phelpsa
posted on 31/1/11 at 11:33 PM |
The vague turn in could be to do with a lack of castor. I seem to remember someone mentioning that indys suffer a bit with this.
brookie
posted on 1/2/11 at 05:53 PM |
rebore 954 some pistons some head work and a good rolling road sould give u around 140 at the back wheels m8
