mads
| posted on 4/4/11 at 10:07 PM |
mounting brackets for brake pipes / flexi hoses
right, this came out in conversation at tonight's south brum meet..
it appears that the MK Indy R chassis does not have pre-welded mounting points for where the brake pipes and flexi hoses meet (both front and back).
so does anyone have any pics or suggestions on where to (and how to) put these - will save me hassle and time when I come to measuring for brake
lines. will also help another Indy R builder from this region.
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
A1
| posted on 4/4/11 at 11:12 PM |
the fronts you just put through the bodywork, at the rears you just put them together right after a pipe clip. could always just stick a wee ali
bracket on too.
deezee
| posted on 5/4/11 at 10:42 AM |
quote: Originally posted by A1
could always just stick a wee ali bracket on too.
Its a little risky using aluminium brackets to support brake unions as they are an IVA fail. Good ole VOSA believe they will fatigue and break.
| posted on 5/4/11 at 11:04 AM |
We manufactured an 'L' shaped aluminium bracket to strengthen the front edge of the side panel and also provide a more substantial
connection for the brake flexi's. There should be pictures in the 'rebuild' section of our website (April) if you want to have a
look..
Phil
mads
| posted on 5/4/11 at 11:20 AM |
cheers Phil. I found the pic in March but when I click image to enlarge, the page is blank... =o/
