matty h
| posted on 20/5/11 at 08:44 PM |
Spring rating
Have a MK with De Dion rear end currently have 180lbs springs on the back and 350lbs on the front car is a bit unsteady over are rough British roads
should I change the spring rates.
danny keenan
| posted on 20/5/11 at 08:51 PM |
hi
what engine do you have fitted?
if you fetch it to the factory i will have a look over it and set it up if you like
thanks
matty h
| posted on 21/5/11 at 09:58 AM |
Thanks,It is fitted with a 2.0 8v vauxhall engine with opel manta box.With protech ali coilovers.
U2U sent.
