tantoelauw
| posted on 17/6/11 at 10:38 AM |
Clutch pedal
Hello,
Recently i've been trying to install a clutch pedal, unfortunatly the action of the pedal is insufficient. The clutch will only move about 30
percent of what is needed.
Does anyone have an idea of how to make it work properly?
Greetings,
2004 MK Indy Blackbird
mistergrumpy
| posted on 17/6/11 at 11:07 AM |
Is it an MK pedal or one of your own design? Sounds like you either need to move the pivot point further towards the top of the pedal or else at th
other end of the cable, make the connection closer to the pivot.
| posted on 17/6/11 at 12:11 PM |
If you're using the standard MK pedals and fitting a ZX12R engine, you must have some other issue/problem. We have a ZX12R and standard pedals
and had to fit a pedal stop to avoid over stretching the clutch cable.
Welcom to the forum BTW
Phil
tantoelauw
| posted on 17/6/11 at 01:52 PM |
Hello,
Well I'm not entirely sure that it's a MK indy pedal, since i bought the packet from a MK indy dealer. A nice guy but kind of chaotic so
it could be that we ended up with the wrong pedal. I'm assuming that if it is an original pedal it would work without any problems. The pedal
looks something like this. Is it supposed to look like that? I will try to move the pivot point but i'm not really convinced that it is
enough.
And yes we had lots of trouble. Partly because of our inexperience, but some thing just wouldnt fit in the designated places. We had to change all of
the engine supports because they were in the wrong place.
danny keenan
| posted on 17/6/11 at 02:55 PM |
you are fitting the wrong pedal.thats the brake pedal.
if you need any help or advise send me a u2u
thanks danny
tantoelauw
| posted on 17/6/11 at 04:58 PM |
Hello,
Are you serious? Well it would explan why the clutch doenst work properly. Strange thing is though we havent got any other pedals which fit in that
place. Thats how we figured that it had to be a clutch pedal. It was the only one which fits.
I'm really confused now. I made a picture of where we are
We adjusted the brake pedal a bit. Originally it had a cilinder of similar size below the cilinder in wich the extensions for the brake cilinder are
fitted. We stiil have that cilinder but it needs a little adjustment so that it will fit.
Are you able to tell from this picture which pedal should go in which place?
Greetings
[Edited on 17/6/11 by tantoelauw]
danny keenan
| posted on 17/6/11 at 05:19 PM |
that is the brake pedal.some one must have u given u the wrong pedal as i cant see the cluch pedal in the pic.
thanks
tantoelauw
| posted on 17/6/11 at 05:47 PM |
Hello,
Well thanks for clearing that up. I will contact the dealer and tell him to send me a clutch pedal.
Greetings
