tantoelauw
| posted on 25/6/11 at 04:26 PM |
Cable stops
Hello,
After I had received the correct clutch pedal, I was on my way again. I am wondering though what i can use for a cable stop. I can't find a
suitable cable stop anywhere.
I needs to be some kind of plug or a cap maybe with a hole, in which the black cable is stopped but the actual clutch cable can run through.
Is there anyone who knows what i can use best to get the job done.
Greetings,
2004 MK Indy Blackbird
big_wasa
| posted on 25/6/11 at 04:59 PM |
Its on the end of the clutch cable isnt it ?
tantoelauw
| posted on 25/6/11 at 05:23 PM |
No it's not at the end of the clutch cable, so i guess that would mean its not really a clutch cable. I think i will have to call my dealer
again.
Where can i buy a mk indy clutch cable? Will any clutch cable do? I don't want to wait for the dealer to send me the correct parts again.
Greetings.
jacko
| posted on 25/6/11 at 05:28 PM |
Give Hellfire a u2u as he is using the same engine as you in a MK indy
The photo above is of a type 9 gearbox clutch cable
Jacko
Davegtst
| posted on 25/6/11 at 07:59 PM |
That tube on mine is for the accelerator cable. The clutch just had a hole (in the wrong place) in the bulkhead. How come your brake master cylinder
only has one outlet?
jacko
| posted on 25/6/11 at 08:11 PM |
The tube is for the clutch cable on my indy but my car has a car engine / box
Coopz
| posted on 25/6/11 at 09:46 PM |
Talk to Mac1, they can supply top hats with a cable adjuster tapped into it correct size! works well I'm using one for my accelerator and clutch
cable.
tantoelauw
| posted on 26/6/11 at 02:58 PM |
Because I have 2 brake cilinders one for the brakes on the frontside and the other obviously for the brakes on the backside. Is that unusual? It was
like that when i bought it.
Anyway thanks for the info everyone.
