New Topic New Reply
Author: Subject: Pinto alternator
mookaloid
posted on 25/7/04 at 07:03 AM Reply With Quote
Pinto alternator
Just got my Indy on the road, all seemed well until I heard a noise from under the bonnet on let handers! It seems the alternator fan is catching the chassis as the engine moves slightly. Has any one tried running the standard Pinto alternator without the fan on?
mangogrooveworkshop
posted on 25/7/04 at 07:49 AM Reply With Quote
They put a fan on there for a reason. When You take it off you will fry it. Get a smaller alt from a suzuki half loaf or other such brands of cars and it will fit no bother at all with plenty space. (could put a five mill spacer under the drivers side engine mount)
[Edited on 25-7-04 by mangogrooveworkshop]
Staple balls
posted on 25/7/04 at 08:02 AM Reply With Quote
indeed, to be quite honest, i'm surprised you managed to get the original alternator in there with it only fouling at times, most people seem to end up using a smaller alternator,
mitsubishi's and ones from bedford rascals (i think) are pretty common, and a few people use ones from 2CVs, but they need a seperate regulator and are a bit of hassle it seems
mookaloid
posted on 25/7/04 at 09:04 AM Reply With Quote
Thanks Guys
posted on 25/7/04 at 10:48 AM Reply With Quote
Can you fit a shorter fan belt?
posted on 25/7/04 at 03:05 PM Reply With Quote
its very hard to fit a smaller belt. i tried, any shorter and you have to put the belt in place before bolting the altenator to the engine, which i never managed. i ended up moving the steering column.
mookaloid
posted on 26/7/04 at 07:26 AM Reply With Quote
Already fitted the shortest belt possible, I think this enabled me to get the original alternator fitted (against the odds!) in the first place!
New Topic New Reply
