New Topic New Reply
Author: Subject: pedal stop
bikkel
posted on 27/7/04 at 07:54 AM Reply With Quote
pedal stop
hello
when fitting my floor mount throttle pedal (MK indy) , it keeps tilting over to the front.
how to fit a pedal stop ( without welding because it powdercoated)
thanks
koen
www.zx12r-indy.tk
posted on 27/7/04 at 09:01 AM Reply With Quote
Koen,
I used a bit of steel strip bent at 90deg, with a hole drilled in one end. Fit this to the pivot bolt for the pedal, so the right angled part sits in front of the pedal arm. Then you can adjust it to stop the pedal where you want it and tighten up the bolt to keep it there.
HTH
Nick
New Topic New Reply
