New Topic New Reply
Author: Subject: brake pipe route
whitstella
posted on 16/7/11 at 02:55 PM Reply With Quote
brake pipe route
hi
i was just about to fit my flexible brake pipes on the car (from the calipers) but i want to know the bset postion to go through the body panel???can they be fixed to the body or through a hole with a grommet ????
has anyone got some pics i can take a look at please cheers steve.
[Edited on 16/7/11 by whitstella]
ReMan
posted on 16/7/11 at 03:39 PM Reply With Quote
Hows this
It was spot on, based on measurements MK gave me.
Never touched anything even on full lock
f flexi
f flexi
6" from bottom. 2.5" from fron edge
*Edited to say,They need to be fixed to the body*
[Edited on 16/7/11 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
macc man
posted on 16/7/11 at 05:36 PM Reply With Quote
I used a support bracket from the chassis onto the body side to give more rigidity to stop the panel flexing. Best to use a piece of flexible tubing as a mock up before drilling anything to check for clearance on tyre.
big_wasa
posted on 16/7/11 at 08:35 PM Reply With Quote
flexi onto the side panel like that has been a fail for a long while.
serieslandy
posted on 16/7/11 at 08:57 PM Reply With Quote
So is a hole with a grommet. It was one of AshG's iva fail points.
big_wasa
posted on 16/7/11 at 09:16 PM Reply With Quote
what was acceptable ?
ReMan
posted on 16/7/11 at 09:21 PM Reply With Quote
Like mine? Why?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
daviep
posted on 16/7/11 at 09:34 PM Reply With Quote
Like mine? Why?
Side panel is too flexible to terminate a copper on, eventually it may fatigue and crack.
Davie
Coopz
posted on 16/7/11 at 09:56 PM Reply With Quote
I located my flexi fixed through side panel, as I think this is the neatest solution! Although a failed IVA overall this passed fine. But its all down to the testers discretion.
L5W
posted on 16/7/11 at 10:05 PM Reply With Quote
I was concerned about this too. Had a chat with Dunk3 at Stoneleigh about his car in general and asked about brake lines through the side panel. His passed ok with the brakes like this at IVA (correct me if I'm wrong dunk3!) so it must be down to the IVA examiner's interpretation.
I welded in an extra bracket to support the joint on mine without the need for a grommet.
Hopefully it'll be ok at IVA!
Lee
[Edited on 17/7/11 by L5W]
daviep
posted on 16/7/11 at 10:56 PM Reply With Quote
Looks good
New Topic New Reply
