mangogrooveworkshop
posted on 6/8/04 at 02:13 PM |
Another plastic tank bites the dust
Mac on the phone .......plastic tank let go and flooded his garage with 20 quids worth of optimax.
The tank has solid mountings with rubber and we are looking to investigate why it failed as soon as possible. Mac had the car out twice round the
houses and then is has just been sat. Our thoughts are that the plastic weld has been attacked by the fuel.
Mad4x4 has kindly loaned a tank to us so we can do the testing needed to get the carbs ect sorted for emmisions & SVA
Thank you very much A H. FIVE ST*R
[Edited on 7-8-04 by mangogrooveworkshop]
stephen_gusterson
posted on 6/8/04 at 03:48 PM |
thats only about a litre isnt it?
atb
steve
macspeedy
posted on 6/8/04 at 04:41 PM |
just to say the car has been round the block twice and was under no pressure at all, apart from gravity.
Viper
posted on 7/8/04 at 08:53 AM |
Mango
If you need a tank, i can make one up for you at a very reasonable cost
http://www.locostbuilders.co.uk/upload/P1010040.JPG
Tim.
mookaloid
posted on 7/8/04 at 09:06 AM |
I am worried about my plastic tank. Do they fail after a period of time or is it usually a manufacturing fault which reveals itself soon after the
first fill up?
In other words mine seems ok at the moment but should I be planning to replace it soon?
Viper
posted on 7/8/04 at 09:31 AM |
I think there are a lot of plastic tanks out there and only a few have had problems. It would seem to have been a bad batch for what ever reason.
bob
posted on 7/8/04 at 10:13 AM |
Mines fine (about 3 years old)and has been carrying petrol for last 18 months.
Its just a bit small
DEAN C.
posted on 7/8/04 at 04:49 PM |
Mine has just failed last week,had fuel in for 4 months sat in garage!!!
Bought mine direct from chris gibbons,so my gripe will be with him.
I have just commisioned a new ally tank from Martin,he CAN weld!
Just a thought, but mine had unleaded fuel in,has anyone elses failed with leaded in?.Just wondered if it was just the unleaded fuel?
Quite why snoopy says its for Martin and Chris to sort out I'm not sure,surely when MK sportscars was split any problems legally stayed with the
business not Martin himself!I have no gripe either way except perhaps with Chris,but I'm not going to lose sleep about it,it's just one of
those things.
Once I've finished a project why do I start another?
Viper
posted on 7/8/04 at 06:59 PM |
Are you implying someone on here selling tanks CAN'T weld?
scutter
posted on 7/8/04 at 07:38 PM |
Before this goes to far
just in case Viper how much are your tanks? Still a good few (insert own time scale here) away from filling mine.
ATB Dan.
posted on 7/8/04 at 07:45 PM |
i think it was more a reference to shady plastic glue, as it would be a bit daft implying you cant weld...!
turns out my new neighbour, an old chap called Dennis, used to be a prof welder. Ran his own special fabrication company making stuff that others
wouldnt do. An example he gave me was a 3 tonne staircase with no vertical supports along its length... he came over to make sure i wasnt going to
kill myself in the beast! he said the used to check theirs with xrays, ultra sound and one other which i cant remember...
Viper
posted on 7/8/04 at 07:46 PM |
Scutter.
you have a U2U.
Tim
macspeedy
posted on 7/8/04 at 08:02 PM |
thanks for the offer viper but i have ordered one from Martin and will be chasing up Chris gibbons myself
Viper
posted on 7/8/04 at 08:06 PM |
Duh should have read mongo's posting a little more carefully
hope you get it sorted mac.
Tim
scuse the spellin i si vodkad
[Edited on 7/8/2004 by Viper]
DEAN C.
posted on 7/8/04 at 10:09 PM |
Viper,the" CAN weld "jibe was about plastic welding!
I've never seen you're welding but I'll be happy to examine yours if you like,I've done a couple of thousand hours of welding
myself.
To be quite honest I'm not sure why the plastic tanks have failed and in all fairness it could be a bad batch of material.
posted on 7/8/04 at 10:14 PM |
the sticky stuff has been implicated in the past...
Viper
posted on 8/8/04 at 01:00 AM |
Dean
for the record, i am an ASME 9 coded welder and have had a lot of my welds tested, i am lloyds registered in TIG, MIG and MMA.
just for the record you understand.
Tim
DEAN C.
posted on 8/8/04 at 10:33 AM |
Hi Viper,
Think I'll take up fishing,got a big bite this time.
Got a few welding papers myself from ages ago,but not to asme standard,welded a few pressure vessels thoughand had them tested .
I'm only a fitter though so I'll stick(MMA)to my hydraulics and bits of wiring as the only welding I've done this year is a couple
of JCB buckets with a big noisy diesel stick set in the back of my van.
All the best DEANO...............
donut
posted on 8/8/04 at 08:24 PM |
I have had 2 tanks from PTM (Plastic tank man) and both failed. I have asked on many occasions for my money back but after months of waiting and
emailing i have been fobbed off with excuses and still no refund!!!
I bought an ally tank from MK and it was 1st class
