metro6r4
posted on 1/11/11 at 10:50 PM |
dry sump on a dragster
hi im building a Haynes lo cost to use for speed challenges and drag racing with a rover k series engine.i found a bellhousing to convert a type 9 to
accept the rover engine however i have to run a dry sump to fit it will this be of any benefit or should ilook for a different bell housing as i dont
want to carry any extra weight i wont be taking corners at speed and it wont be on the road if that helps
James
posted on 2/11/11 at 12:35 AM |
quote: Originally posted by metro6r4
i dont want to carry any extra weight
Sure the Haynes is the right car for you then? It's a fair bit heavier than a Locost I'd imagine!
James
- Muhammad Ali
SeanStone
posted on 2/11/11 at 07:08 AM |
a dry sump system is generally heavier than a standard oil system, so i'd consider your other options first
phelpsa
posted on 2/11/11 at 07:56 AM |
James
And it's IRS which can be a bit of a disadvantage off the line.
metro6r4
posted on 2/11/11 at 07:21 PM |
well its not cost me a lot at the moment and it will be easier to work on than my last ride and a lot lighter hopefully but more importantly he power
is going through the right wheels id of liked to run a bigger car but its on the limit of what i have room for fingers crossed it will get rid of my
wheel spin issue im intending to run nearly 300 hp with nitrous maybe more if i can find a supercharger for sensible money
what does irs mean and will the dry sump make a difference to performance?
nz_climber
posted on 3/11/11 at 04:31 AM |
Would have thought a aero of 7 makes it very disadvantaged for drag racing. Would be more looking at mid engine fully enclosed car. Dry sump will make
a tiny bit more power but probably not noticeable.
http://aarons7.wordpress.com
scudderfish
posted on 3/11/11 at 06:36 AM |
Why would dry sumping increase power? You have a bigger oil pump to run. I thought the primary reason for dry sumping was to avoid oil starvation
under high lateral G loads around corners. Corners are not really something to worry about at Santa Pod.
Yazza54
posted on 3/11/11 at 06:46 AM |
Your k series isn't going to last 5 minutes at 300hp. The last one that was supercharged that I know of just kept blowing head gaskets and he
was only at enough boost for 200hp. This was a seriously professional setup, now been ditched for Honda power...
I'm unhappy cos I eat and I eat cos I'm unhappy
Oddified
posted on 3/11/11 at 08:48 AM |
Dry sumps are meant to increase power slightly because the crank case is at a small vacuum, but it's only small and i doubt it's worth it
in drag racing when oil starvation isn't a problem and your then carrying a load more clobber down the strip.
Plenty of people do use the K series on the strip with nitrous, but 300bhp maywell be past where it's happy/reliable.
Ian
