macspeedy
| posted on 10/8/04 at 04:25 PM |
suspension setup, more help needed
what would people recommend as a starting setup for the indy suspension, toe in...
[Edited on 11/8/04 by macspeedy]
subk2002
| posted on 10/8/04 at 04:32 PM |
you want toe out for sva mac
| posted on 10/8/04 at 04:41 PM |
recommended by MK:
parallel - 0.5deg toe-out.
Camber - 0 deg / \ Front
Camber - 0 deg / \ Rear
[Edited on 10-8-04 by Hellfire]
macspeedy
| posted on 10/8/04 at 08:52 PM |
also
we need to know the setup of the front camber and castor and rear camber. Does anyone know the starting values for these?
bob
| posted on 11/8/04 at 10:52 AM |
MAC
I took my car to SVA with the front wheels at zero zero toewith 18lb tyre pressure,it attempted to self centre just and they passed it if it had
failed i would have just give it a hanfull of toe out for the test.
I've got 0.5 degree neg camber all roundand the front hubs are leaning back as far as they will go.
Also my GAZ dampers are set up at 20 clicks clockwise from zero all round and my springs are 15 threads up for ride.
It seems to be fine and the more i drive it the self centreing seems to get better.
hope this helps
