richijenkin
| posted on 11/8/04 at 12:37 PM |
Engine Mounts
Dudes..
Im after some engine mountings to hold a 1800 cvh Saphire in my MK Indy. Dont suppose these are standard brackets are they? or will I have to get some
made up?
garage19
| posted on 11/8/04 at 01:04 PM |
If you are taking the engine out to change the mounts i would take this chance to......
Throw it in the nearest skip and get some pinto or even zetec beans under the hood!
Surrey Dave
| posted on 11/8/04 at 01:51 PM |
1800CVH ...........Prejudice!!!!!!!!!
That's the kind of really helpful advice you get when you mention 1800CVH......
You would think it was the engine equivalent of having aids............
Not a bad engine , difficult to tune 'cos not much available for them in standard form
Have skimmed an gasflowed the head on mine ,and also fitted a Weber DGV in place of the little Pierburg.......
Smooth & Torquey , low maintainance , cheap, VERY cheap , this is Locostbuilders after all ...
richijenkin
| posted on 11/8/04 at 01:53 PM |
Shouldnt need to take the engine out, but if I do, I'll be replacing it with a proper engine..... Yamaha R1.
garage19
| posted on 11/8/04 at 02:14 PM |
Not AIDS!............. just genital warts!!
locoboy
| posted on 11/8/04 at 03:07 PM |
Richie has the R1 bug then!thought you broke the mountings ages ago? have you not been driving it or did you manage a quick repair job
Locoboy
richijenkin
| posted on 11/8/04 at 03:55 PM |
ox sorted the last mounting disaster, but its broken again, in a different place this time (not on the weld). AAARRRGGGHHHH.
Surrey Dave
| posted on 11/8/04 at 04:50 PM |
Engine Mounts.........
richijenkin
| posted on 11/8/04 at 07:02 PM |
So its just a case of welding someup then... Hmmmm... what does a welder look like?!?!?
[Edited on 12/8/04 by richijenkin]
