Author: Subject: Side Repeaters for IVA
wz1musik
posted on 23/2/12 at 01:56 PM Reply With Quote
so i finished my build now and took the car for pre test inspection by the guys at MK, very helpful however they said that the side repeaters fitted to the Scuttle would not be suitable. they said i had to put them on the front wings or rear wings.
thats going to be a big problem with wiring and messing around so what if i was to
1. Put the side repeaters on long stalks from the scuttle (just for iva obviously)
any have any idea if this will work?
thanks
loggyboy
posted on 23/2/12 at 02:02 PM Reply With Quote
Soundss like what I was planning, then use the mouting holes made for the arms to mount some simple side repeaters post IVA.
wz1musik
posted on 23/2/12 at 04:23 PM Reply With Quote
yes tahts the idea,
do you think it will work?
Kind Regards
Wesley
loggyboy
posted on 23/2/12 at 04:27 PM Reply With Quote
As long as you get the angles, will need to stick out quite far - nearly as wide as the rear arches as you need to get 5 degrees visability to the rear.
jimmyd
posted on 23/2/12 at 06:46 PM Reply With Quote
I've recently noticed a couple of vans with side repeaters on stalks so it must be acceptable.
J
rodgling
posted on 23/2/12 at 07:27 PM Reply With Quote
I put mine on my front wings. They look good there, I think, and IVA were happy with that.
Nash
posted on 23/2/12 at 11:51 PM Reply With Quote
The solution must not look temporary. I failed the first time on this exact issue. I bought some cheap stick on repeaters from CBS and ran the wiring around the cycle wing rubber edge. up the underside of the wishbone and connected it to the wiring feeding the front indicators. I then removed the scuttle repeaters and put reflectors in the holes.
Passed no problem. The solution cost me less then a tenner.
HTH's.................. Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
NeilP
posted on 25/2/12 at 11:47 AM Reply With Quote
Has this changed between SVA and IVA? Mine on scuttle...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
