athoirs
posted on 3/9/04 at 09:16 AM |
emission test results
The results of the SVA test were..
rpm- 2688
co - 0.03
hc -104
lambda -1.08
getting the lambda low enough without the hc going up was the problem . I also found that the lambda was a bit unstable and the exhaust was
"burbling" a bit.I am going to a garage on monday to set up the carbs first ie balance etc.. any help would be appreciated!!
theconrodkid
posted on 3/9/04 at 11:22 AM |
an air leak will cause high lamba,make sure its well sealed
who cares who wins
pass the pork pies
Mk-Ninja
posted on 3/9/04 at 02:52 PM |
Seal the exhaust with silicon sealant, it works realy well once it has smoked a bit.
I'm sure I've got one, just don't know where I've put it
mangogrooveworkshop
posted on 3/9/04 at 03:48 PM |
dont use exhaust paste gum gum. It ate my exhaust on my mondeo. its acid based.
