New Topic New Reply
Author: Subject: Rivet size for ali trim strip ?
Not Anumber
posted on 12/6/12 at 02:42 PM Reply With Quote
I'm doing a colour change and need to remove the ali trim strips above the side panels on both sides which are held on with very large headed rivets. Does anyone know what size these are and whether they can be fitted with a bog standard rivet gun ?
whitestu
posted on 12/6/12 at 03:14 PM Reply With Quote
Yes, I fitted all my rivets with a small had rivet gun.
I used countersunk rivets on the ali trim, but used large head ones elsewhere.
Stu
stevegough
posted on 12/6/12 at 03:20 PM Reply With Quote
drill one out, then measure the hole that's left?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
renetom
posted on 12/6/12 at 03:42 PM Reply With Quote
rivets
Hi probably 3/16"
Std rivet gun ok , just change the nozzle to fit the larger rivet.
varied nozzles are normaly attached to the gun handles.
good luck
René
New Topic New Reply
