steve m
posted on 14/6/12 at 11:49 AM |
Help TDCI mondeo wont start
Hi
Ive changed the fuel filter, (next to the rear beam) on my 2008 TDCI mondeo, and the car ran for about two mins, and cut out
I cant start it now!
It does not have the fuel pump bulb
any idea's
regards
steve
RichardK
posted on 14/6/12 at 11:59 AM |
I had one of those and it turned out to be either the crank position sensor or cam position sensor, think it was cam but was a few years ago, do you
know anybody with a code reader? Maybe that would give you a clue.hope you get it sorted,cheers rich
Gallery updated 11/01/2011
JAMSTER
posted on 14/6/12 at 12:52 PM |
maybe take off the filter and fill with diesel and replace
steve m
posted on 14/6/12 at 02:24 PM |
i had taken the filter off, again, and refilled the bowl to the max, and reassembled it, and still no joy,
but, ive solved it now
Basicly there is a schraeder valve by the pump, so i took the valve out, and put a tube and funnel on to the valve,
and basicly back filled the system with the funnell, and then removed the funnel, and blew int the pipe to force the fuel down and back up the feed
pipe, untill i ran out of puff, and diesel !
removed the pipe, fitted the valve,
and it started first time!
mark chandler
posted on 14/6/12 at 04:28 PM |
You need to be very careful doing that, even cracking the injectors can introduce enough dirt to screw up the injectors
posted on 14/6/12 at 04:54 PM |
And possibly the engine!
dray13dad
posted on 14/6/12 at 06:03 PM |
On later Mondeo/ford/peugoet can be a right sh... to bleed after doing fuel filter as bleed is on the return side.Best use wd40 done the air intake
and keep going like that but make sure starter motor does not get too hot. or take in for a long tow. there is i think a blleed kit just come on to
the market for these darn cars.(I hate doing filters on these later cars) would say set a side at lest an hour and half to get it back running after
doing filter.
