hughpinder
posted on 18/9/12 at 01:02 PM |
USB stick suddenly write protected
I have a strange problem. A guy I work with was backing up a 4Gig directory of photos using VISTA onto a 16Gig memory stick. It got to about 2G (the
old FAT16 limit) and stopped with a message that the stick was write protected (it doesn't have a write protect switch, its formatted as FAT32).
The stick shows up on windows VISTA, XP, 7 , OSX 10.6/10.7 and HPUX11 as a read only device and nothing I've tried lets me change that (access
control lists included) He's happy for me to reformat it to get back a useable usb drive, but none of my systems seem to want to touch it.
Anyone else had this, and how did you sort it?
Thanks for any ideas
Hugh
posted on 18/9/12 at 01:49 PM |
Are you sure the computer isn't saying it's write protected because it can't write to it IE it's FUBARd?
hughpinder
posted on 18/9/12 at 02:02 PM |
That may well be true, but hopefully someone will come up with something I haven't seen or heard of before. You can see all the files it did
copy to the stick, and open them/copy from the stick. Since its a 16G stick, I wouldnt be surprised to find its 8 blocks of 2G, and something nasty
has broken internally.
Regards
Hugh
Ivan
posted on 18/9/12 at 02:11 PM |
Is it a new stick - if so it might well be a fake 16 Gig stick with only 2 gig really available.
ashg
posted on 18/9/12 at 02:12 PM |
any chance its a HP memory stick? there was a problem with a batch of them going write protected. HP released a patch to fix it.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Fatgadget
posted on 18/9/12 at 07:36 PM |
![](/images//smilies/shocked.gif)
posted on 18/9/12 at 08:13 PM |
Sadly quite common on unbranded/fake branded Chinese stuff, e.g. MP3 Players, flash sticks even SD cards.
[Edited on 18/9/12 by MikeRJ]
hughpinder
posted on 19/9/12 at 10:02 AM |
Thanks for the help. Its a memorex one and does show up as 16G. I have now convinced myself it broken.
Regards
Hugh
MikeFellows
posted on 19/9/12 at 12:05 PM |
obvious things first...
The memory stick doesnt have a write protect tab physically on the device does it?
if your sure it doesnt and your happy to lose the data that is stored on it do the following
(presuming your using windows 7, its not much different for XP or vista)
1. click start
2. right click on computer and select Manage
3. under storage click disk management (wait while it loads), you should now see a list of disks available
4. you should now see all disks on your computer including any removable storage
5. in the top half of the screen, you will see the drive letter that corresponds to your Flash Drive, lets pretend its E: (yours could be anything)
6. scroll down in the bottom half of the screen and you will find volume E: and details about it something like MYPENDRIVE (E: ) 16GB Healthy (primary
partition
7. Right click and select Delete Volume read dialouge box and click yes (you might get another dialog box depending if something is accessing the
drive, again cread it and click yes). You have now removed the parition from the drive
8. Right Click the drive again, select new simple volume
9. click next, Windows will now automatically try to use all available space on the pen drive, but check its trying to use the max disk space and
click next
10. pick a drive letter and click next
11. choose a file system, give the drive a name (as standard its New Volume), untick peform quick format so we can get it to sort of check the drive
for you as it formats (if it is a 2GB card tricked to reporting 16GB, it will trip up here). click next
12. click finish
13. in the bottom half of the screen you will not see your drive formatting, this might take a while, so leave it be and go have a cuppa or even
better a beer
14. when its done test your drive as normal
let me know any error messages or if you get stuck on the above
[Edited on 19/9/12 by MikeFellows]
hughpinder
posted on 19/9/12 at 01:05 PM |
Thanks for that Mike, I'll try that tonight
regards
Hugh
