Sloan85
| posted on 14/10/12 at 05:21 PM |
Riveting the floor - What to rivet into?
First day working on the car today.
I am unsure whether I should be riveting into the flat steel as well as the square sections? Are these flat steels for the seat rails?
I have marked them up with masking tape (see pic) but thought I'd check before drilling.
Cheers!!
mads
| posted on 14/10/12 at 05:30 PM |
i just did mine to the square steel as the flat parts are for the seats/runners. Seems plenty sturdy enough.
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
Sloan85
| posted on 14/10/12 at 06:30 PM |
Thanks for the quick reply. Ill leave the runners then.
jossey
| posted on 14/10/12 at 07:29 PM |
Woooooowwwww is that a wooden electric guitar in the background........
David Johnson
Sloan85
| posted on 14/10/12 at 07:31 PM |
Its my old squire bass that is half way through being refurbed. Going to attempt a black and white swirled paint job when I get time
Davg
Mark it up nd dril then u want some pu adhesive on there b4 you rivet. Also easier if you are going lucky reverse to cut slot at the back b4 you fit
the floor.
Cheers D
Oh yeah 1 hole in the middle of the flat steel straps is good too
[Edited on 14/10/12 by Davg]
Sloan85
| posted on 14/10/12 at 07:34 PM |
got some adhesive with the kit so should get the floor done this week. Also MK supplied the floor powder coated with the slot for the electric
reverse already cut out.
Davg
| posted on 14/10/12 at 07:39 PM |
Chop chop then get in there!
