New Topic New Reply
Author: Subject: Picture request - relay holder position under scuttle?
Sloan85
posted on 3/12/12 at 09:23 PM Reply With Quote
I am looking for photos showing how the relays are fixed under the scuttle. Does anyone have any photos? I am planning on making a holder from aluminium but wanted to see how other people have done it before I buy anything.
Cheers!
mark chandler
posted on 3/12/12 at 09:48 PM Reply With Quote
No pictures, I got a bracket that holds 4 relays off a range rover.
I needed an additional one for the ECU, just bent a U bracket from an off cut of Ali and two little nuts and bolts.
[Edited on 3/12/12 by mark chandler]
posted on 3/12/12 at 10:30 PM Reply With Quote
You can buy Interlocking relay sockets that clip together like Lego they also come in versions that have a built in slot for blade fuses.
http://www.vehicle-wiring-products.eu/VWP-onlinestore/relays/sockets.php
posted on 3/12/12 at 10:39 PM Reply With Quote
A couple of pics showing mine. I made an ally plate fitted between the scuttle hoop and top chassis rail. All relays and fuse holders were secured to this with the wires grommetted (sp?) back through the panel and secured with loom tape (don't fit the loom tape until you're 100% sure it all works and you don't need any more wires!) and p-clipped to the chassis. I chose to fit them under the scuttle for protection from the elements, but it does make them hard to reach if you need to.
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 3/12/12 at 10:49 PM Reply With Quote
I did the same...
I bought some ripnaults relay holders and mounted them on the ally. Relays and holders I found cheapest from ECS electrical in Southend - phone them and tell them RS are cheaper and they will price match it
[Edited on 3/12/12 by Barkalarr]
40inches
posted on 4/12/12 at 08:25 AM Reply With Quote
Mine is a bit more complicated than most, Kliktronic, power steering and bike electronics.
Hope it never goes wrong
Bizarro
posted on 4/12/12 at 04:08 PM Reply With Quote
Similar to mine, piece of ally under the scuttle:
Fuse mounting
Fuse mounting
Attach to it as you go along!
Fuses relays
Fuses relays
Macbeast
posted on 4/12/12 at 05:08 PM Reply With Quote
Relays have a metal mounting strip which is rivetted to a bit of aluminium angle.
mackei23b
posted on 4/12/12 at 08:03 PM Reply With Quote
Here is my old MK:
Ian
New Topic New Reply
