doobrychat
posted on 4/7/13 at 11:46 AM |
Sierra lsd question
Hi all..
I have read on here that if you remove the bolt on flanges from the diff then push in ones fit..
is that correct?
thanks in advance..
tilly819
posted on 4/7/13 at 11:51 AM |
Not for a LSD only for an open diff
The splined stubs are different lengths for an LSD
sorry
Tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
mcerd1
posted on 4/7/13 at 11:56 AM |
^^what he said - the Ford LSD stubs need to be longer on one side than the other
assuming your looking to fit a LSD to a car with push-in driveshafts you've got 3 options:
1 - swap all the axle bits for bolt-on ones
2 - make some hybrid driveshafts (you need the right size of push-in shaft to do this)
3 - use an aftermarket LSD and keep the rest of your existing setup (quaife, tranX, etc... )
[Edited on 4/7/2013 by mcerd1]
Mr Whippy
posted on 4/7/13 at 12:02 PM |
I have 2 good bolt on drive shafts for sale
£50 the pair + postage
