New Topic New Reply
Author: Subject: Flat oval Indy top bones
dozracing
posted on 25/10/04 at 06:32 PM Reply With Quote
Pic attached. Please contact me off list if this is of interest to you. Rescued attachment mk-top-wishbone.jpg
posted on 25/10/04 at 07:21 PM Reply With Quote
NICE!!!
shortie
posted on 25/10/04 at 07:31 PM Reply With Quote
VERY NICE!!!
cerbera
posted on 25/10/04 at 07:45 PM Reply With Quote
VERY VERY NICE!!!
Ben_Copeland
posted on 25/10/04 at 07:48 PM Reply With Quote
V... no i sharn't continue that.
Looks good darren, should have no trouble shifting them !
Ben
Locost Map on Google Maps
Enter Your Details Here
Northy
posted on 25/10/04 at 07:57 PM Reply With Quote
Daren,
Do you fancy doing a "wide track" Avon front end?
Graham
Hugh Jarce
posted on 26/10/04 at 03:59 AM Reply With Quote
Nice looking quality.
Not being in the least bit critical, Darren, just curious; why did you terminate the outer ends of the aero tube like you have rather than run them into the camber adjuster outer? (I realise the adjuster would then need to be longer.)
It's a bit hard to tell, are they actually aero tube, or just oval?
Have you tried bending any of the tube?
The pay isn't very good , but the work's hard.
posted on 26/10/04 at 07:26 AM Reply With Quote
Actually, it looks a very good way of doing it! The almost straight weld runs look a lot easier than the book design.
Aesthetically, it makes no odds as you can barely see the wishbone ends anyway.
rgds,
dozracing
posted on 26/10/04 at 07:28 AM Reply With Quote
I'd love to do a wide track Avon front end. Contact me via email and we'll work together to do it.
Hugh. You sort of answered the question yourself. Its a bit of a compromise between getting plenty of tube attached to the end of the wishbone, and having too long a camber adjuster.
The are flat oval, although if you wanted to be really tarty i could make them in full tear drop aero tube. No they are not bent. I've posted before about not being a lover of bending tubes.
Kind regards,
Darren
Hugh Jarce
posted on 26/10/04 at 07:45 AM Reply With Quote
I wasn't worried about the asthetics; I think they look really smart.
Thanks for the clarification Darren, I was just wondering if there was a trick I was missing.
zetec
posted on 26/10/04 at 08:34 AM Reply With Quote
Can I have a set without powder coating?
Have you got a set in stock?
Next question. What castor angle are they set for? Say with my MK Sierra upright mushroom set in the centre position.
Let me know if you have a set and I'll pop over and get them.
dozracing
posted on 26/10/04 at 04:49 PM Reply With Quote
Hi Zetec,
You can have them un-powdered if you like, but because of the way i process the powder coating in batches i don't actually pay to have these bones done, so i can't offer a discount on them.
I will have the next batch of 5 sets in next week, so sure pop over and pick a set up.
They are jigged from a set of Indy wishbones, so they will give you the same castor angle as standard. Which from memory is 5.3 degrees.
Kind regards,
Darren
locoboy
posted on 27/10/04 at 11:22 AM Reply With Quote
Looking good
so i guess im right in thinking that there are a direct replacement for the indy item and as such take MK bushes not the GTS ones?
Am i also right in thnking that there are NOT of any use on a book chassis?
Locoboy
dozracing
posted on 27/10/04 at 04:26 PM Reply With Quote
They are a direct replacement for the MK wishbones, but, i do use my polybushes and these are provide with the bones if need be. Although i suspect we get them from the same supplier.
I do a different version for the book which is dimensionally as per the book, except for the bush sizes.
Kind regards,
Darren
locoboy
posted on 28/10/04 at 08:20 AM Reply With Quote
I have been doing a bit of maths (badly maybe!) and comparing the size of your bush tubes with that from MK, am i right in thinking that your tubes have a wall thickness of 18g (1.2mm) and MK are 12g (2.64mm) - this would make sense if your both using the same ID tube @ 28.5mm
Where's Carol Vordman when you really need her
Locoboy
dozracing
posted on 28/10/04 at 08:33 AM Reply With Quote
The bush tubes i use are 3mm wall, but the ID is as you say 28.5.
Kind regards,
Darren
locoboy
posted on 28/10/04 at 10:33 AM Reply With Quote
Is my maths letting me down here?
On the bush tube PDF on GTS tuning website it states 1.25 inch 18g tube is required.
1.25 inch OD =31.75mm
less the ID of 28.5 = 3.25, divide this by 2 to get wall thickness of 1.62 (16g) not the 3mm Darren just mentioned.
either Darren is talking about the new indy wishbones which use a different spec tube to the ones on the PDF or the PDF is wrong.
Locoboy
dozracing
posted on 28/10/04 at 02:19 PM Reply With Quote
The PDF is wrong-ish.
The PDF was orginally done for another project, and the sizes work out for these bushes, but, for production road car wishbones i have changed supplier and now use a 35mm OD CDS tube with a 3.2mm wall.
I ought to update the pdf really. So don't worry your maths are working out fine.
Kind regards,
Darren
mad-butcher
posted on 28/10/04 at 05:16 PM Reply With Quote
look very nice,but i thought martin kicked the top ball joint mounting up for a particular reason, something to do with not fouling the ball joint or what ever..but there again i'm no engineer
tony
dozracing
posted on 28/10/04 at 05:21 PM Reply With Quote
If you look closely Tony, the bush is kicked at the same angle.
Its hard to see in the picture as the bones are black and the angle isn't very apparent.
Kind regards,
Darren
[Edited on 28/10/04 by dozracing]
DEAN C.
posted on 29/10/04 at 10:04 PM Reply With Quote
Nice wishbones Darren!
Smells better here than on other topics!
Once I've finished a project why do I start another?
New Topic New Reply
