New Topic New Reply
Author: Subject: Peugeot GTi engine in an Indy?????
donut
posted on 3/10/02 at 05:25 PM Reply With Quote
I have been offered a good 1.9 GTi Peugeot engine for almost nowt but i'm duboiuse about putting it in an Indy as it's a transverse jobby. Has anyone done a similar conversion, if so whats involved?
Smacca
posted on 25/10/02 at 09:20 PM Reply With Quote
Some Sierra diesels had Peugeot engines. I think the Peugeot petrol and diesel engines are based on the same design, so it means there should be comaptible gearboxes or at least adaptors for RWD. Might work?
donut
posted on 26/10/02 at 08:24 AM Reply With Quote
Yeah i think it may be worth looking into a bit more. The peugeot gti engine is a seriouse bit of kit and would make the Indy really fly!
UncleFista
posted on 26/10/02 at 04:42 PM Reply With Quote
Pug GTi RWD 'box ?
Right, this is at least 3nd hand info so it may or may not be true
The Pug GTi engine has the same bellhousing bolt pattern as the PSA diesel engine used in the newish LDV Pilot van.
Its said that if you obtain a bellhousing from the above mentioned van it'll bolt on to a Rover SD1 gearbox and that'll bolt straight up to the GTi engine.
Must admit though, if it was me, I'd go for the Mi16 engine
Click here for a good Pug engine info source
HTH
Tony Bond / UncleFista
New Topic New Reply
