zetec
posted on 4/10/02 at 08:30 PM |
Fuel pump.
I need some advice on what fuel pump to fit. I'm fitting a 2ltr Zetec with throttle bodies, with luck about 160BHP.
I have a secondhand 2ltr Sierra injection pump, but I'm not sure it's up to the job. I've fitted one of PTM tanks and could fit a Mondeo in tank
pump but I'm not sure if it will fit.
Any suggestions?
CairB
posted on 5/10/02 at 08:07 AM |
I'm not sure of the excess capacity of the pinto pump but I suggest that you ensure that there is a filter on the inlet of the pump and that the flow
capacity is checked with the filter in. I had a pump fail, when I stripped it down it was due to a tiny sliver of plastic from the plastic fuel tank
and I had spent ages cleaning it out.
Colin
