New Topic New Reply
Author: Subject: Gear Linkage bits
shortie
posted on 26/11/04 at 08:01 PM Reply With Quote
Gear Linkage bits
Just looking at my gear linkage kit and the is a long shaft and short shaft rose jointed at each end, the pivot bit that goes on the footwell, the bit that goes on the gear lever on the engine and then there is another piece of tube about 2inches long drilled and threaded but I can't work out where it goes.
I reckon if I use this bit between the footwell attached pivot and the short shaft I can mount the pivot higher on the footwell and avoid my brake pipes.
Just wondered if anyone else had a similar bit and if so where it went??
Rich.
shortie
posted on 27/11/04 at 08:54 AM Reply With Quote
Just fitted the front bit and the little short bit makes an excellent extension piece so that the pivot can be mounted higher on the footwell. All seems to fit nicely, just the lever to do now.
Rich.
mad-butcher
posted on 27/11/04 at 04:05 PM Reply With Quote
i'm curious as mine only had 2 rods any chance of a fitted photo to see extention as really you need everything as paralel to each other as possible
tony
shortie
posted on 27/11/04 at 06:00 PM Reply With Quote
no probs, will get a picture tonight.
Rich.
shortie
posted on 27/11/04 at 09:53 PM Reply With Quote
Here's the pics I promised....
http://www.shortshouse.co.uk/files/MK/Gear%20linkage/Gear_Linkage1.jpg
http://www.shortshouse.co.uk/files/MK/Gear%20linkage/Gear_Linkage2.jpg
http://www.shortshouse.co.uk/files/MK/Gear%20linkage/Gear_Linkage3.jpg
http://www.shortshouse.co.uk/files/MK/Gear%20linkage/Gear_Linkage4.jpg
http://www.shortshouse.co.uk/files/MK/Gear%20linkage/Gear_Linkage5.jpg
Rich.
shortie
posted on 28/11/04 at 10:55 AM Reply With Quote
I wonder whether MK put the extra bit in as alot of people wanted to do the same as us.
Rich.
New Topic New Reply
