Harrodbear86
posted on 23/3/15 at 04:54 PM |
Mk Indy Roll Cage
Hi All,
I have recently purchased an Mk Indy, it currently has a pretty pathetic roll bar at the back due to having the full wet weather kit, but I'm
looking to do quite a few track days this year and wondered which is the best roll cage to go for.
I assume that if I go for a full cage then the wet weather kit will be redundant.
Any advice would be greatly appreciated.
Thanks again.
Danny
jossey
posted on 23/3/15 at 05:59 PM |
Call MK
You could get the cage built to go over the body so wouldnt effect the cage but not sure how it would look.
get a removable cage with the cage being bolted to a new bar so it can be removed to put the wet gear on?
David Johnson
kj
posted on 23/3/15 at 07:36 PM |
Try teegray NE7ER ENGINEERING
Think about it, think about it again and then do it.
austin man
posted on 23/3/15 at 08:01 PM |
Have you got a current picture of the car, MK should be able to retrofit the full cage onto your car using the existing rear hoop give Danny a call
