New Topic New Reply
Author: Subject: Camber angle.
floaty
posted on 31/8/15 at 10:10 AM Reply With Quote
Camber angle.
Hi I bought a mk indy from someone else and I don't think that the camber angle is correct I've done a little research and I've come up with 1 to 1 and half 1/2 degrees, what should it be for normal Road use. Cheers Steve Float
daniel mason
posted on 31/8/15 at 10:23 AM Reply With Quote
Might be worth having a decent geometry setup. Don't alter camber angles until ride heights are set correctly!
If your happy with ride height,spring rate,wheel sizes,tyre pressures etc then a simple camber change may do the job. But a full setup with corner weights will transform the car if not already done
posted on 31/8/15 at 12:24 PM Reply With Quote
I think you mean negative camber -1 to -1.5 degrees.
How much depends on tyres and and what roads you drive.
After setting camber the toe setting will need checking.
New Topic New Reply
