New Topic New Reply
Author: Subject: Indyblade fuel pipe
ReMan
posted on 13/12/04 at 09:54 AM Reply With Quote
Indyblade fuel pipe
Anybody got any archive pics, or suggestions as to a good way/route for running their fuel pipes into the engine bay and up towards the carbs with a `Blade engine, thought i`d sussed it but any ideas welcome before I start bending!
Cheers, Colin
shortie
posted on 13/12/04 at 10:54 AM Reply With Quote
I ran mine along the tunnel on the opposite side to the brake pipes and wiring (just in case!) using some 8mm copper pipe bought from Wickes, I had loads left over so if you want some I can send you some no problem.
I then stopped the copper just at the engine end of the tunnel by the footwell and then used some braided fuel pipe to connect between this and the carb T-piece.
HTH,
Rich.
posted on 13/12/04 at 10:59 AM Reply With Quote
I'm using a Pinto, but I routed mine the same way as Shortie, also with Ø8mm copper pipe.
I found it easiest to straighten the pipe of the big coil and feed it through the tunnel from the fuel tank end. Then I gradualy formed it by hand round the bulkhead and along one of the lower chassis rails up to where the fuel pump is on the engine.
HTH
Nick
ReMan
posted on 13/12/04 at 06:59 PM Reply With Quote
Yes i`ve got the pipe and all that, really wondering where to end the solid (copper pipe and start the flexi to the carbs, thinking SVA and all that about keeping it all secure and tidy, whatever the rules are for clamping pipe runs, solid or flexible?
New Topic New Reply
