New Topic New Reply
Author: Subject: Rear Upright to hub carrier
phoenix70
posted on 15/12/04 at 11:45 AM Reply With Quote
Does anyone know what size of bolts are used to attach the Sierra hub carrier to the MK Rear upright (Disc Brakes), I kind of assume it is the same as the one that normally attach then to a sierra, but I don't have them.
TIA
Scott
posted on 15/12/04 at 12:58 PM Reply With Quote
I re-used the ones from my donor Sierra.
I cleaned the threads in the MK uprights after painting and IIRC they were M8 or possibly M10 threads. I think the bolts might be a higher tensile rating than normal, so might be worth sourcing from Ford or at least using 12.9 ton rated socket cap bolts.
HTH
Nick
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 15/12/04 at 03:31 PM Reply With Quote
Yup original donor ones are probably best! maybe give your local ford dealer a call- i had to buy various odd bolts from Peoples in edinburgh- very helpful and not actually all that expensive!! often have them on the shelf!
GeoffB
posted on 15/12/04 at 05:21 PM Reply With Quote
GOT MINE FROM FORD DEALER 86P+VAT EACH,THEY ARE 12.9 STRENGTH
phoenix70
posted on 15/12/04 at 07:13 PM Reply With Quote
Cheers Guys,
I'll give my local Ford dealer a call
New Topic New Reply
