Kev99
| posted on 17/12/04 at 09:05 PM |
Brake Balance
On the Indy what form of brake balance do you use.
Also do most pepole use the sierra master cylinder
| posted on 17/12/04 at 09:29 PM |
Hi Kev,
A few paople (me included) have used the rear brake compensator from a Fiat Uno. It's located under in front of the passenger side rear wheel
by the suspension trailing arm.
You can use it to make an adjustable compensator/bias valve.
See www.winchester7.com December for some pics of mine.
HTH
Nick
Kev99
| posted on 18/12/04 at 10:11 PM |
Thanks have to take a trip to scrap yards
carnut
| posted on 19/12/04 at 12:34 AM |
I started with a std sierra setup with xr4x4 brakes front and rear with a sierra master cylinder. This managed to get through sva however I found
about the 3rd time i drove the car i was locking up the rears. I have now fitted a willwood bias valve from rally design (www.raldes.co.uk i think)
and this has totaly transformed the braking performance of the car.
I believe a brake balance bar is the best option but can be dificult to set up correctly where a bias valve is easy to fit and set up.
carnut
ReMan
| posted on 21/12/04 at 08:24 PM |
Carnut, What discs and pads were you using please?
bob
| posted on 21/12/04 at 08:40 PM |
FIAT uno brake valve
bob
| posted on 21/12/04 at 08:43 PM |
closer pic
carnut
| posted on 23/12/04 at 12:12 PM |
Reman,
All standard discs and pads. Vented 9" on the front and solid 9.5" on the rear.
thanks
Carnut
