royrid
posted on 18/12/04 at 08:49 PM |
MK fuel tank?
Hi everyone, havn,t been on the site for some time {been too busy building} {not}. Any way she,s coming on slowly, but i,ve got a question to ask!!
The MK fuel tank. Correct me if i,m wrong, but i take it that looking from the rear of the car, the pipe on the left front of the tank is the fuel
supply, and the right hand side one is the breather? If i am right, then how come that the right hand pipe {suspect breather} does not enter into the
tank? IE: you can,t blow through it!!
Could it just be a manufacture cockup??? Thanks for any help.
shortie
posted on 18/12/04 at 08:51 PM |
You just need to drill it through if you want a breather pipe.
Rich.
royrid
posted on 18/12/04 at 08:55 PM |
Cheers Rich. Thought as much, but wanted to make sure.
shortie
posted on 18/12/04 at 10:30 PM |
I'm putting a non-return valve in a tube above the tank on mine.
Rich.
athoirs
posted on 19/12/04 at 11:38 AM |
get one from here-http://www.bsr-aerotek.com/fuel18.htm
much cheepness!!
DEAN C.
posted on 19/12/04 at 04:38 PM |
I've used a Rover 216 tank valve (little red and black plastic thing) came free when removing internal fuel pump.
A lot of lads have just used bicycle innertube valves,just as cheap and easy to get hold of.
Once I've finished a project why do I start another?
