sonic
| posted on 25/5/16 at 04:50 PM |
Seat tapping on the rollbar
A mate of mine has an MK Indy with the GRP seats in, both his dad and him who drive the car are 6ft 5 plus and have to push the seat right back as far
as it will go to fit in.
The problem is whilst driving the car the top of the seat ( head rest part ) taps on the roll bar and is driving them mad, as well as taking the
powder coat off.
Any ideas for a cure?, thought about some sort of pipe lagging foam but it to thick.
thanks
CosKev3
| posted on 25/5/16 at 05:05 PM |
Foam tape?
CosKev3
| posted on 25/5/16 at 05:06 PM |
Look at this on eBay 3m Black Single Sided Foam Tape Closed Cell 20mm Wide x 3mm Thick
madteg
| posted on 25/5/16 at 05:25 PM |
Put a couple of washer under rear fixing bolts to lift back of seat up, would imagine 2mm washer should do the trick
sonic
| posted on 25/5/16 at 05:31 PM |
Like the spacer under the seat fixing idea, thanks for that I will pass it on
gremlin1234
| posted on 25/5/16 at 06:06 PM |
or indeed tip it back a little, so it rests firmly on the roll bar
hizzi
| posted on 25/5/16 at 09:13 PM |
i have spacers under the back of my seat rails in a haynes roadster works a treat. i did it to make the seat back angle and chassis angles match, that
gave me another chunk of legroom with the seat able to go further back
| posted on 25/5/16 at 10:27 PM |
Surely you can put it one click forward??
peter030371
| posted on 26/5/16 at 07:27 AM |
Remove the seat runners and bolt seat straight to floor
| posted on 26/5/16 at 01:36 PM |
I'd fit some self adhesive foam padding to the roll bar to protect it and remove the tapping noise. Halfords do some cheap for number plate
fixing foam pads 2-3mm thick in black that should do the job.
rodgling
| posted on 26/5/16 at 02:02 PM |
I had the same problem - I used this stuff on the edge of the seat where it made contact:
http://www.woolies-trim.co.uk/p-1458-titanfast-edgetrim.aspx
| posted on 27/5/16 at 07:52 AM |
Looks like it would work and from experience Woolies are good to deal with as well.
