david
| posted on 8/6/16 at 11:35 PM |
fuel pipe clips
what type of clips have i to use to hold the fuel line in place, will the plastic ones pass iva
loggyboy
| posted on 8/6/16 at 11:40 PM |
Yep. As long as its secure. Can be p clips or push/snap on ones.
I dont believe there is a specified spacing, bit elec loom is spec as 300mm max, so work to that.
Mistral Motorsport
joneh
| posted on 9/6/16 at 06:23 AM |
I bought 15mm rubber lined p clips and put both the brake and fuel line on the same clip. I modified each clip by putting in two pipe off cuts and
tapping the middle to make each clip into an M shape, keeping both pipes apart.
