ChrisJoyce
posted on 2/9/16 at 08:21 PM |
Indy r/rr differences
Hi all !
New here, great forum!
I'm in the early stages of planning an my build, one thing I'm wondering is the difference between the Indy r and the rr chassis if
any?
From looking at the mo website I believe the rr has adjustable wish bones? but are there any other differences?
It may be a daft question so I apologies in advance if it is fairly obvious.
Thanks all.
CosKev3
posted on 2/9/16 at 08:30 PM |
All the wishbone to chassis mounts are rod ends on the RR,the R uses poly bushes.
If you are going for a full roll cage the tubing is a smaller diameter on the RR.
On the RR's I've seen the gear lever mount on the BEC RR is raised above the top chassis rail on the tunnel.
ChrisJoyce
posted on 2/9/16 at 08:52 PM |
Thank you for the reply CosKev3
Do you mean the mount on the actual wishbone, are the mounts on the chassis the same, I guess what I'm trying to ask is can rr wishbones be used
on the r chassis?
Thanks for the info on the roll cage.
CosKev3
posted on 2/9/16 at 09:02 PM |
Not 100% sure but would say the mounts on the chassis will be the same,they will just use spacers with the rod end bearings to take up the space.
